Getting access to 2D arrays elements
As I said, you code makes absolutely no sense and is not decipherable (truncated image, hidden wires, wires going in all directions, [i] wired to the "direction" input of boolean crossing (?????!!!!!), a file read function with nothing connected, etc.)
All you need is a simple state machine the size of a postcard. Start with a hardware-free simulation until everything works, then substitute the drivers.
I still recommend to do the tutorials, then start over from scratch. You are in a rut and you need to back out of it!
Message 11 of 15
(938 Views)
I did this. Here is screenshot of what I tried to achieve. When I change index I can read all rows the way I needed
Message 12 of 15
(934 Views)
No. Just no!
(All it shows are glaring mistakes and convoluted Rube Goldberg code. It does NOT show what you are trying to achieve at all!)
Message 13 of 15
(930 Views)
Why are you not taking the advice of altenbach and going through the free tutorials? You clearly need that.
Message 14 of 15
(905 Views)
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 15
(899 Views)
