Getting an Error when trying to save my vi.
When I attempt to save my vi, I now get an error that says " Cannot load Help Information of "Aquire_Signal_Data.vi".  I just started getting this error today, and have made several important changes to the vi and need it to be saved.  Anyone ever get this error and if so, how did you correct the problem.
P.S. The only option the warning givesme is to "Cancel Save" and when I click on the button I get an error that says it can't find a file and then doesn't save anything.
Mike
(3,443 Views)
hi,
have u included any help information for ur vi..if so,
Check the help path in the VI properties under documentation catagory..if the path is not correct one..then this error may come..
by the way "Aquire_Signal_Data.vi".  is ur vi or sub vi...check this and reply me..
hope this will give you an idea..
(3,423 Views)
The vi is one that I created from a blank vi.  I created it for the project I'm working on, and finished the first version and was trying to create an executable.  If the problem is not having this help file, how fo you create one and point to it?
Mike
(3,406 Views)
Hello Mike,
You shouldn't need any sort of help file just to create and save a VI.  If you go to File >> VI Properties and then set the Category to Documentation, is there a filepath in the Help Path box?
Cheers,
Clint M
(3,394 Views)
The Documentation property is blank, and I have never messed around with it.  However, I did build an application from the vi, does that somehow effect the original vi, cause I didn't have problems saving before building the an application from the vi for the second time.  I also attached a screen chot of the vi prop dialog box and the error i was getting.
Mike
(3,389 Views)
