Ni-Scope 3.3 driver install
I run LV 7.1 , LV Run Time 8.0 , MAX 4.0 , Ni-Daqmx 8.0 and Ni-Scope 2.1.
Now I need Ni-Scope 3.3 for my PCI 5911 hi speed digitizer.
Could I " overwrite " the present Ni-Scope 2.1 or should I deinstall 2.1. en install 3.3 from scratch ?
Thanks for help ( couldn't find the answer in the archive ).
Peter.
(3,311 Views)
You can uninstall NI-Scope 2.1 and then install 3.3.  Installing NI-Scope 3.3 on top of NI-Scope 2.1 will not be a incremental update. It will be a complete replacement.
Karsten
(3,299 Views)
Karsten,
Thanks.
Meanwhile I seem ( not sure .. ) to understand that Ni-Scope is part of Ni-Daq(mx).
Does this mean that I have to deinstall my present NiDaqmx 8.0 and reinstall NiDaqmx 8.60 before installing Ni-Scope 3.3 ?
If so, does MAX install automatically within installation of NiDaqmx ?
Thanks again,
Peter.
(3,290 Views)
Hi Peter,
NI-Scope depends on NI-DAQmx for low level device detection and simulation. So when you upgrade to NI-Scope 3.3 NI-DAQmx will also be upgraded to the minimal version that is requered for NI-Scope, you can find this inforamtion in the readme file of NI-Scope.
MAX is part of all NI Driver software, thus also NI-Scope and NI-DAQmx. the MAX will also be upgraded to the minimum version required by the NI-Scope 3.3.
Hope this helps,
Karsten
(3,285 Views)
Karsten,
This is very helpful indeed.
I can go on installing  my NI-5911 hi res digitizer now.
Peter.
(3,273 Views)
