Getting corresponding data from xy graph
Hi
Appreciate anyone who can give me some idea on how to solve this. I've tried browse through the examples here but none seems to meet my requirement.
I'm trying to get the corresponding y value in a graph. Say, if my user specify windspeed 5.5 m/s in my GUI, the corresponding power output will automatically appear in the indicator array. This has to be done without using cursor. Any idea on how to do this?
thanks
Message 1 of 13
(5,621 Views)
you can add to an array by using a build array function
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 13
(5,616 Views)
Hi..
My obtained data for windspeed is all in round numbers....therefore i need to get the corresponding output y (values) of these (x values) 5.3m/s...6.6m/s.. 7.4 m/s from the graph..do u mean i just have to connect a build array to the build graph?
Message 3 of 13
(5,612 Views)
Accepted by topic author Guitar
1- This is a job for the "interpolate 1D array" function (in the array subpalette). See attachment.
2- As soon as possible, try to forget the use of Express vis.
3- No need to multiply by one in the For loop
Chilly Charly    (aka CC)
Message 4 of 13
(5,604 Views)
something like this?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 5 of 13
(5,598 Views)
Thanks Harold & Chilly !!
Message 6 of 13
(5,591 Views)
Hi
Just for learning's sake...what if a 1d array of data x is keyed in and the result in data y is needed (1d array) ?  The input of the threshold in threshold 1d array cannot be anything with 1d array or 2d array...Is there any alternative besides using Express VI for interpolate and threshold 1D?
Curious
Thanks!!
Message 7 of 13
(5,567 Views)
I don't understand your question. I believed that this was exactly what was illustrated in the vi attached to my previous message.
Message 8 of 13
(5,557 Views)
Hi
Then let me explain it this way....Can I change the "Numeric" input in the VI  to a 1D array if a few data (from y axis) is needed from the graph? Or else, I have to key in and change the value of "Numeric" a few times...
Appreciate your opinion
Thanks!!
Message 9 of 13
(5,543 Views)
Add a for loop, and wire in your "few data" 1-D array. Wire out the interpolation result as 1-D array. Auto-indexing will do the job !
Message 10 of 13
(5,494 Views)
