Getting corresponding data from xy graph
Hi
Thanks for the response. I have created the vi but it seems that threshold 1D array can only accept a non-array value as the element input. Maybe another alternative method should be used to solve this?  With this i attach the vi. There's an error in it. Please advice.
Thanks!!
Message 11 of 13
(590 Views)
No.  Put the threshold and interpolate functions INSIDE the For Loop.  The X and Y arrays will be wired through but with normal tunnels.  Delete the element indicator, it goes to the ouput tunnel that is autoindexed to Output Array.
Message 12 of 13
(581 Views)
Oh Yes!!...Finally understand what you mean....Thanks..Here's the solution!!
Message 13 of 13
(574 Views)
