GiGe camera waits till there is a TTL signal takes a picture and then waits again for another TTL signal (IMAQdx)
Hello , I have a problem with a GIgE AVT camera.
All I want to do is make the camera wait and each time there is a TTL signal snap a picture and save it to the disk.
I have spent hours and hours trying to make this work but I had no luck !
Could someone with knowledge of the IMAQdx drivers help me please !?
I really can't find a solution to this problem!
(2,649 Views)
Hi ymartz,
It seems there are two ways to accomplish this, depending on your hardware.
If you have a trigger input to the GigE camera, then I suggest using this with the TTL signal. If you also need the TTL signal in your LabVIEW then you can sample it with a DAQ device too.
The Community example below demonstrates how to do this by creating an artifical trigger with a counter, but the code you would need to use is the setup on the top, which should configure the camera to use the trigger.
https://decibel.ni.com/content/docs/DOC-15346
If this is not possible with your camera, then I suggest using a software buffer and triggering it to be filled. The Community example below uses this technique.
https://decibel.ni.com/content/docs/DOC-7501
Hope this helps!
(2,646 Views)
Hello LaThoS,
thanks for your reply .
What i am trying to do is use an AVT GS660 which actually has a hardware trigger input and all i am trying to do is put it in a while loop and make it wait untill there is an external ttl signal, then take a picture , save it and then wait for another ttl signal !
I 've seen the examples but i cannot see how they are going to be usefull to me since there is no hardaware ttl signal on the cam( https://decibel.ni.com/content/docs/DOC-15346)
I am attaching my sample code.
Could you please help me figure it out ?
Thanks in advance,
yannis.
ps:the problems that i am facing is that on ttl the camera starts saving the same image continisously till i stop the loop !
(2,642 Views)
Hi Yannis
Has this problem now been resolved based on the outcome of your other forum post: "Save images displayed on Vision->Image Display, on disk!"?
Regards
Marshall B
National Instruments UK & Ireland
(2,614 Views)
