Showing results forย
Search instead forย
Did you mean:ย
Global replace library path in call library function in multiple project VI files
I am working on a project with many VI files, a large number using a call library function node.  The call library function node makes a specific function call to a C-callable API (DLL).   The single library path has changed and we need to update the path in each node in every VI using the API (DLL).   Is there a tool or a good way to globally search and replace the path string across VI files spread across multiple project subdirectories?
(5,705 Views)
Yes!
You can change the library path using scripting with the VI Snippet below. You just need to pass the new path (as a constant) and a VI Reference (you could make this a control in a subVI).
Then, you can acquire a list of all the VI references in your project, and pass them to this VI - it will change the path of the library in the CLFN node (here, it will change the first CLFN node found in testCLFN.vi to C:\new.dll). You should add a For Loop autoindexing rather than using the Index Array node, and then you should be good to go.
GCentral
(5,673 Views)
Accepted by topic author big.tuna
Attached is a VI that might do exactly what you want, with some minor path constant modifications and the deletion of a diagram disable structure.
Your mileage may vary, and I don't promise it won't destroy your project/computer/world.
Good luck ๐Ÿ™‚
GCentral
(5,670 Views)
