01-03-2017 02:40 AM
I developing LabVIEW controlled experiment using version 2016. Unfortunately, I will need to transfer it to LabVIEW 8.5. When saving project to version 8.5 I'm loosing ability to work with my classes.
I made a simple test which you can see on the Figure below:
I do not understand which library I'm missing. What could be the solution to this problem?
Solved! Go to Solution.
01-03-2017 02:57 AM - edited 01-03-2017 02:58 AM
Hi saldenisov,
you're talking about a VI conversion from 2016 to 8.5!
You know there are >8 years between both LabVIEW versions?
You know there are several compiler changes in between?
General advise: Do the coding stuff in LabVIEW 8.5 when you need LV8.5 sources. Upconversion to LV2016 is much safer than backconversion…
Your 7z file contains several VIs. Apparently the "Read Numeric 2"/"Write Numeric 2" are runnable after I included them in your class…
01-03-2017 03:12 AM
They are runnable because they were done in 8.5 LabVIEW. So your advice is to work in 8.5, what I really do not want to do...but:(
01-03-2017 03:51 AM
Were classes introduced in LV8.5?
01-03-2017
03:57 AM
- last edited on
11-13-2025
01:26 PM
by
Content Cleaner
01-03-2017
05:06 AM
- last edited on
11-13-2025
01:26 PM
by
Content Cleaner
@GerdW wrote:
Hi Yamaeda,
OOP/classes were introduced in LV8.2…
I didn't think it was that old, seems people started using it ~2013. 🙂
/Y
01-05-2017 11:01 AM
I found a solution:
I continued to work with LabVIEW 2016.
I've simply dublicated classes I needed in 8.5 and 2016 by simply coding them twice.
When I downgrade to 8.5 version I use classes developped in version 8.5, when I go back to 2016 I start to use version of classes developped in 2016.
Stupid, but it works:)
