Going from LabVIEW 2016 to 8.5 stop classes vi from operating.
I developing LabVIEW controlled experiment using version 2016. Unfortunately, I will need to transfer it to LabVIEW 8.5. When saving project to version 8.5 I'm loosing ability to work with my classes.
I made a simple test which you can see on the Figure below:q1.png
I do not understand which library I'm missing. What could be the solution to this problem?
(3,804 Views)
Hi saldenisov,
you're talking about a VI conversion from 2016 to 8.5!
You know there are >8 years between both LabVIEW versions?
You know there are several compiler changes in between?
General advise: Do the coding stuff in LabVIEW 8.5 when you need LV8.5 sources. Upconversion to LV2016 is much safer than backconversion…
Your 7z file contains several VIs. Apparently the "Read Numeric 2"/"Write Numeric 2" are runnable after I included them in your class…
(3,785 Views)
They are runnable because they were done in 8.5 LabVIEW. So your advice is to work in 8.5, what I really do not want to do...but:(
(3,778 Views)
Were classes introduced in LV8.5?
Qestit Systems
Certified-LabVIEW-Developer
(3,764 Views)
Hi Yamaeda,
OOP/classes were introduced in LV8.2
(3,757 Views)
@GerdW wrote:
Hi Yamaeda,
I didn't think it was that old, seems people started using it ~2013. 🙂
/Y
Qestit Systems
(3,740 Views)
Accepted by topic author saldenisov
I found a solution:
I continued to work with LabVIEW 2016.
I've simply dublicated classes I needed in 8.5 and 2016 by simply coding them twice.
When I downgrade to 8.5 version I use classes developped in version 8.5, when I go back to 2016 I start to use version of classes developped in 2016.
Stupid, but it works:)
(3,707 Views)
