Gradual Rise
I have a pulse train vi that rises gradually from duty cycle 0.0 to 1.0. It is not properly done though it works. Is there a better way? The vi is attached. It is in LV6.0
(3,323 Views)
Hallo labview1958,
you do the same operation 7 times with only one parameter changing.
So I would prefer to do this in a loop instead of a sequence. This way the (experienced 🙂 programmer can see the whole program at once.
Have a look at the changed vi!
(3,317 Views)
Hello labview1958,
forgot to mention:
Please do not use a white colored front panel (at least not in demonstration vi's/examples).
It's very irritating if you are used to grey front panels and white diagrams...
(3,308 Views)
Thanks. What if I have a Pulse vi interspersed with measue frequency vi? I suppose I cannot use the LOOP.Any way to solve this. The Vi is attached.
(3,293 Views)
I showed you a better way when you asked the same question at http://forums.ni.com/ni/board/message?board.id=170&message.id=131634#M131634.
(3,291 Views)
