sharing front panel graph
i want the option to display data continuously acquired or data retrieved from a file, but on the same graph, not simultaneoulsy, one or the other. i have a case statement for the source (daq or file) the daq case contains configuration and a while loop continuously acquiring data and displaying it,no hassle there. my 'file' case has the bit to read the file and retrieve data, i then get abit stuck. i've played around with 'locals' and loops within loops, but aren't getting anywhere really. i've attached the code to help see what i'm doing.
thanks in advance.
(2,976 Views)
You don't really give enough information on which graphs you want to re-use, etc.
I am making the assumption that you want to process the file data the same way as your sampled data. A simple solution is attached, modify as needed.
(2,964 Views)
thanks altenbach, i spent ages tryign to pass data between loops and cases without success.  brill!
(2,951 Views)
