Graficar señal en labview / Plot signal in Labview
I have the problem with x (time) not with y (amplitude)
Message 11 of 22
(1,415 Views)
Hi Cristina,
which problem do you have with x axis?
Message 12 of 22
(1,401 Views)
I don't know how to ajust the x (time) , in properties i modifie the amplitude ( 0-100 for example)  but when i run the vi the x scale doesn't take the value that i choosed.
Message 13 of 22
(1,391 Views)
I want to representate my signal in time fuction.
Message 14 of 22
(1,388 Views)
Hi Cristina,
a chart just counts the samples as they are written to the plot (by default), it does not plot the signal vs. time (by default). Additionally a chart has a limited history so it will only display a certain amount of samples…
When you want to plot signals vs. time you should use waveforms!
LabVIEW comes with a lot of example VIs, there are also examples explaining the usage of charts and graphs!
Message 15 of 22
(1,379 Views)
hopefully this is will help
Message 16 of 22
(1,381 Views)
Can you make the value that is to the left of the x-axis move and not stay fixed at 1:00?
Message 17 of 22
(1,370 Views)
Accepted by topic author cristina.lopez
is that what you want ???
Message 18 of 22
(1,366 Views)
Yes, but how did you do it?
Message 19 of 22
(1,356 Views)
And , you can inicialize the time in 0?
Message 20 of 22
(1,353 Views)
