Graficar señal en labview / Plot signal in Labview
in your chart i expand the length to have more wide sample as you wanted
for the x axis i removed the auto-scale tick so the axis continue working.
if you find it as a solution, please mark it as solved
Message 21 of 22
(321 Views)
right click on the x axis and go to properties > display format.
choose either absolute time or relative time depends what you wants from the application.
but i doubt that you can initialize the time to zero without using other function and property node. not quite sure about it.
Message 22 of 22
(320 Views)
