Showing results forΒ
Search instead forΒ
Did you mean:Β
Graph:Expport Image help
Hi All,
I'm doing some report generating and am using an invoke node on a graph to export its image to an EMF file that I then send in to report with "Append Image to Report".  This seems to be the optimal format given that "Append Image to Report" won't take a PNG.  However, the Export Image from the invoke is leaving out the Y axis label.  Am I missing a setting somewhere to get that included?  I'm not having much luck in my searching so far.
Thanks in adnace for the help.
Greg Cole
β€œIt is not the ship so much as the skillful sailing that ensures the prosperous voyage.”
(3,078 Views)
Hi Greg,
I reproduced a VI based on your process, and I am able to create both the emf and the HTML report that have images of the waveform graph with the Y axis. I'm not sure what I did differently from you, but I have attached the .emf, .html, and my vi for your perusal.
Hopefully you can determine what I have done differently.
-Sam F, DAQ Marketing Manager
(3,059 Views)
