Graph:Expport Image help
Hi All,
I'm doing some report generating and am using an invoke node on a graph to export its image to an EMF file that I then send in to report with "Append Image to Report".  This seems to be the optimal format given that "Append Image to Report" won't take a PNG.  However, the Export Image from the invoke is leaving out the Y axis label.  Am I missing a setting somewhere to get that included?  I'm not having much luck in my searching so far.
Thanks in adnace for the help.
Greg Cole
“It is not the ship so much as the skillful sailing that ensures the prosperous voyage.”
(3,077 Views)
Hi Greg,
I reproduced a VI based on your process, and I am able to create both the emf and the HTML report that have images of the waveform graph with the Y axis. I'm not sure what I did differently from you, but I have attached the .emf, .html, and my vi for your perusal.
Hopefully you can determine what I have done differently.
-Sam F, DAQ Marketing Manager
(3,058 Views)
