Graph data from different SubVI's
I am trying to graph data from two different SubVI's. In the main VI I have two SubVI's with some info and one graph for each subvi. I just need to have one graph including all the information from both VIs. I have tried a lot of things and I cannot do this. I think that the easiest way is to place everything in one SubVI, unfortunately I cannot do that, these two VI's should stay separate
Attached is a simple example of what I want to do.
Thanks for the help!
(3,102 Views)
Hi Hernar,
      In your example, SubVI1 and SubVI11 both execute and generate a single value for each loop of MainVI - is this how the finished program will work?  If so, it would be much simpler without references and makes the update of a multi-plot chart almost trivial.  Sometimes people launch SubVIs that run continuously and independently, often producing data to be used elsewhere in the program (like in Main) - is this what you had in mind for SubVI1 and SubVI11?
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,087 Views)
I don't uderstand why you have to do things with references. Simply use plain data wires and connectors. 😉
Now you can simply unbundle the two subVIs output and combine it before graphing. I no longer have LabVIEW 7.0, so here's a picture. Modify as needed.
Message Edited by altenbach on 11-17-2008 11:44 PM
(3,074 Views)
Thank you for your replies. I tried your suggestion altenbach and now it works!
Best Regards,
Hernar
(3,056 Views)
