Graph multiple plot curseur
Accepted by ibahr
One problem is that if you would just remove the outside points, the graph will connect the edge points. If you want gaps, you should use a plot style that has no interpolation.
If you want to just hide all outside points, you can substitute NaN.
If you just want to zoom into the range between the cursors, you could just change the Ymax and Ymin via property nodes and disable Y autoscale.
You simply need to decide what you want!
Message 11 of 14
(810 Views)
Thanks for your help. The first solution resembles what I wanted to do.
Message 12 of 14
(797 Views)
Accepted by ibahr
Message 13 of 14
(794 Views)
thanks !
Message 14 of 14
(789 Views)
