Graph of an alternating output
Hey Everyone,
I'm currently investigating reading and displaying multiple signals using serial (RS 232) communication with an instrument.
So far, I have managed to implement the reading of the multiple signals and a display of the output in a 'text' format.
However, I have become stuck when it comes to displaying the output in a graphical format.
I have tried many ideas, but my latest idea was to try and use arrays to get around the alternating signals...
I have now become perplexed as to how I can get around the problem, as using the 'split signals' VI doesn't work on a 1 output signal with an alternating value.
I have attached my most current test VI as reference.
Any ideas as to how to solve this problem would be greatly appreciated.
Thanks!
(3,162 Views)
I can't view your VI (I'm on LV 2014), but what does your text data look like?
(3,148 Views)
Nobody has your instrument and your code is full of "weird" constructs. Can you attach a VI that operates on simulated data (e.g. formatted iteration number) instead of serial reads?
Why do you have a 2D array if it only ever contains a single column of two elements? Seems way overkill.
I don't understand what you want to display or what you perceive as a problem. Please explain in much more detail.
(3,135 Views)
