Perforce greatly increases project load time
I work with a large LabVIEW project routinely (>4000 VIs) using LV2103 that usually loaded in what I would estimate as less than a minute on my computer. We source control this project using Perforce. I recently configured LabVIEW to access my Perforce workspace from within the LabVIEW project using the Source Control tab in LabVIEW options. I absolutely love checking files out from LabVIEW and being prompted to add newly created files to source control, but now my project takes about 15 minutes to load instead of about a minute. Has anyone else noticed significantly increased load times when using Perforce in LabVIEW? Does anyone have any suggestions on how to reduce this load time?
Best,
jppb
(4,126 Views)
Hi jppb,
I have not used Perforce, but I noticed a significant delay after installing the Viewpoint Tortoise SVN toolkit. I have now uninstalled the toolkit and do my commits through the windows explorer.
(4,119 Views)
Best,
jppb
Maybe the first thing it does is to connect to the repository and get the status of all the files.  Perhaps this is a convenience kind of option that you can turn off?
Bill
CLD
(Mid-Level minion.)
(4,089 Views)
Hi billko,
Unfortunately, there doesn't appear to be any such options in the Source Control section of LabVIEW options, where everything else about Perforce was configured.
(4,017 Views)
@Gregory wrote:
Hi jppb,
Yes, I've experienced the same with their toolkit.  For me, it's a fair tradeoff for stuff like integrated file rename which takes care of things on both the LabVIEW side AND the TSVN side.  Before it was a two step process where you would rename the file in the LabVIEW project/library and then have to repair the move in TSVN (if you wanted to keep the history of the renamed file).  This wasn't a problem if you only renamed one file, but if you happened to rename a couple of files with similar names, good luck remembering the old names.
To the OP:
Sorry I couldn't help you.  😞
Bill
CLD
(Mid-Level minion.)
(4,007 Views)
