Graph voltage not matching input
Double check that you're reading the right terminals with your voltmeter. Remove all extra code (the DC shift, etc) and confirm that your raw signal is coming in the way you expect. If it's not, then you have a terminal configuration or wiring issue.
Cheers
Message 11 of 18
(2,708 Views)
Here's my raw data, with no routines. The green sinewave is the channel in question...
Message 12 of 18
(2,699 Views)
And I'm pretty positive I'm ok with the wiring...other than the alligator clips I'm using.
Message 13 of 18
(2,696 Views)
Here's the graph with a 1.5v (AA) battery. The signal seems good, no?
Message 14 of 18
(2,687 Views)
If I divide the values going to the graph by 1.35, this adjusts the voltage to match my benchtop multimeter linearly. hmmm
Message 15 of 18
(2,653 Views)
After some reading I've concuded that I'm reading Pk2pk voltage in Labview and RMS voltage on my benchtop. Oh, gosh. I need to do some reading.
Message 16 of 18
(2,634 Views)
Accepted by glskinner84
Oops, I drafted up a reply a while ago but forgot to hit send. I was going to say the 1V you were reading might be RMS because that's about where I would expect RMS to be on your sine wave.
Why do you think its Peak to Peak in LabVIEW?
Cheers
Message 17 of 18
(2,623 Views)
It's an AC signal. Shouldn't labview be reading the pk2pk voltage? It makes sense, the labview voltage is about 35% higher than the RMS voltage read from my benchtops.
Message 18 of 18
(2,608 Views)
