Graph with multiple Y scales
As you can see in the snippet, I am trying to plot a Graph with multiple Y scales. What do you think is wrong with it to get the following error.
Possible reason(s):
LabVIEW:  Invalid property value.
(5,222 Views)
You only have a single scale.  You'll want to create the scales before trying to index them.  The property node only accesses the scales.  It doesn't create them.
Try the attached VI
(5,215 Views)
Thank you. But what did you do to index the scales?
(5,203 Views)
Accepted by ziedhosni
I didn't change anything to the indexing.  You already wrote that code.
I right-clicked the scales you already had and clicked "Duplicate Scale" to create the second and third.  Once they existed, your property node worked fine as it was.
(5,199 Views)
