Graph with two different scales for two signals, but autoscaling
Hi..!
I am looking for a smart solution integrating two signals in one graph using different scales.
Autoscaling is welcome.
Thanks for your hints.
ping
[LabVIEW 8.2]
(2,618 Views)
Hi ping1,
you can use two axes. right click on the first one and select -> copy...! Now you can use different scalings for both.
Hope it helps.
Mike
(2,614 Views)
thank you.
that was the first step to the right direction..
is it possible to define one axis for each signal and independent autoscaling?
ping
[LabVIEW 8.2]
(2,611 Views)
Hi ping1,
yes it´s possible. You can assign every signal to one axis using a property node.
Mike
(2,609 Views)
I found it at the moment...
thank you anyway.
[LabVIEW 8.2]
(2,607 Views)
