Graphic scale labels and different fonts
hello all
I have a vi with 4 waveform charts on it. When I develop on one machine, a windows XP pro machine, I get the y axis labelling the way I want it, but when I move to another machine i use for development (these are home and office machines) this one a Windows 2000 Pro machine, the y axis scaling on the charts is ruined, specifically, the hash marks appear in with the actually label numbers. The numbers on the Y-Axis are overwriting the hash marks rather than appearing beside them as they should. And there does not appear to be anyway to fix this y axis labelling display problem short of deleting the waveform chart and making a new one, which is very cumbersome and time consuming given there are four of them as well as a n
umber of Property nodes for each, all of which have to be re-wired etc when I replace the charts.
Is there a way around this problem?
Thanks.
Thanks.
(2,653 Views)
Are you using "special fonts"? Outside the basic types installed by MS?
Maybe the font you are using was not installed in the other machine, so when it looks up the "missing" font, it replaces it with the closest thing... In your case it could be "webdings" or something.
Start by checking if the same fonts are installed in both PCs. If not you have an alternative. Find and install the missing font in your other machine, or change the font in your vi to one available on your other machine.
-enjoy-
JLV
(2,653 Views)
thanks, will look in to that
(2,653 Views)
(2,653 Views)
