Graphical User Interface
I am doing a program for automating a process and I am doing the coding in LabVIEW. My question is can I create a GUI different from LabVIEW front panel. Create a separate GUI for eg: just a screen with Start and Stop and connect my LabView program to it. When I press start the process starts and when I stop the process stops. So what I want is, every time I want to run this process, I don't need to open LabView, except this GUI which has the LabView code and this GUI is connected to the external system which also has the LabView code. So is this possible or do I need to open LabVIEW front panel every time I want to run this process? Thanking You.
Sincerely
Govind
(3,944 Views)
Accepted by govindsankar
Why don't you just build an executable and then you don't need LabVIEW installed on the machine that you are running on.  You will just need to install the Run-Time Engine and any drivers you use.
(3,935 Views)
crossrulz is right, you are not supposed to run your VI from the development environment. Because that means you would have to install the LabVIEW development environment on every computer you need to run a program on.
You build (compile) an executable and deploy the executable and required runtime support as these are free to distribute licence free.
LabVIEW will even make an installer that contains your executable and all the required runtime support files for you, just like any other software.
=== Engineer Ambiguously ===
(3,911 Views)
Thank you
(3,908 Views)
