Graphing Directed Motion in Labview
I was wondering if it was possible to graph directed motion in Labview. That is, I am trying to graph the motion of the top of a joystick and the direction it is moving in, perhaps with an arrow or some other sort of head. Since the joystick has a center, it would also need to start from the center. Thank you in advance for any help on the matter.
(4,201 Views)
What do you mean by "Graph"?  Are you looking for a simple visual indicator of the current joystick position or do you actually want to chart the history of its motion?
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(4,199 Views)
I'd like the whole history with the ability to reset, with a direction indicator on the same display.
(4,192 Views)
just tracking the joystick postion shouldbe straight forward since LV ships with JoyStick function that you can plot on an XY graph but now the complicating follow-up question....
Q:
Does the joystick represent the velocity of some imaginary object that has mass inertia etc?
Ben
(4,187 Views)
Nope, it should just track position and the direction that it last moved in. I was wondering how to do it so that I can also extend this to other such cases where directed motion needs to be mapped. Also, where is this vi?
(4,179 Views)
Olivia can help with that!
Explore that palete and look at the help files.
After you init the joystick OUTSIDE a while loop read the postion and add the new value to an array (use a shift register to buffer reading from iteration to iteration) and update an XY graph.
It is a good exercise to start out.
I could make for an electronic version of an Etch-a-Sketch*.
Ben
* copywrite Ohio Arts ?
(4,173 Views)
