Graphing wait period in Case Structure
I have a VI that is outputting a wave to a linear actuator. The linear actuator should engage then wait a period of time.
Rightnowthetheprogramcurrentlyexecutestheoutput to the device butIwouldliketobeabletoseethewaitperiodonthegraph. It would be nice to have the wait period be at the new offset as well.
I have tired to wire a local variable to the graph inside the false structure however this did graph the pause.
The main VI is the Sinewave generating (KNS)X01 the other two are subVI's
Does anyone have any ideas!?
Thanks!
(2,652 Views)
Hi kspink,
From your code, what I see is that it plots the waveform graph and waits. Graph is not ploted while it is waiting. I'm not sure what do mean by "butIwouldliketobeabletoseethewaitperiodonthegraph". Perhaps you could plot out in a diagram on what do you actually want to see?
Warmest regards,
Lennard.C
Learning new things everyday...
(2,605 Views)
