Grouping instruments together in the front panel
I have designed a LV program in 6.0 where I choose which part of the program to run. As a result I have a lot of instruments etc. cluttering my front panel. Is it possible to group all the instruments into groups. When I run a particular choice of my program only those instruments in that group show up while the rest are safely hidden from view. It could be something like hide/unhide instruments.
(3,033 Views)
Use a Tab Control. You can also switch between tab pages programmatically and hide the tab pane if you like...
bye,
manga
(3,031 Views)
What is tab control? What is tab pages? Can you give me a simple vi in lv6.0 that has those things?
(3,021 Views)
How can I explain in words what is a Tab control? It's a normal control like many others in Labview.
I'm not sure 100% that you can find it also in your labview version, but I think that it's better you do some search in LV Help and Examples, you'll learn something useful..
bye,
manga
(3,018 Views)
Hi
As far as I know tabs are not available in LV6.0 and LV6i.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,011 Views)
Look in your array and cluster controls section for the tab control. It is in version 6.1
(3,003 Views)
