Gtting error 7 message
No changes have been saved to the vi's in the ni library, but i keep getting erro message?
(2,873 Views)
Does the path control (terminal all the way on the left) contain a valid file name before you run the VI?
(2,869 Views)
Is there a way to change it so it dosen't have to contain a valid file name before running the VI?
(2,867 Views)
You can use the File Dialog VI in the File I\O>>Advanced palette instead of the control. This will allow you to pick a file.
___________________
Try to take over the world!
(2,858 Views)
