Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Gtting error 7 message
celiowin
Member
07-24-2005
11:05 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
No changes have been saved to the vi's in the ni library, but i keep getting erro message?
error 7.bmp 770 KB
0
Kudos
Message
1
of 4
(2,959 Views)
Reply
Re: Gtting error 7 message
altenbach
Knight of NI
07-24-2005
11:46 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Does the path control (terminal all the way on the left) contain a valid file name before you run the VI?
LabVIEW Champion
0
Kudos
Message
2
of 4
(2,955 Views)
Reply
celiowin
Member
Author
07-24-2005
11:59 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Is there a way to change it so it dosen't have to contain a valid file name before running the VI?
0
Kudos
Message
3
of 4
(2,953 Views)
Reply
tst
Knight of NI
07-25-2005
01:24 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can use the File Dialog VI in the File I\O>>Advanced palette instead of the control. This will allow you to pick a file.
___________________
Try to take over the world!
0
Kudos
Message
4
of 4
(2,944 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
