Guitar tuner
hello friend,
Can u post your code if possible..?
Message Edited by Malhar on 07-13-2009 04:46 PM
Greeting from India,
Malhar
Message 11 of 13
(2,921 Views)
hi if you see this and you still  have that code could you post it please thanks
Message 12 of 13
(2,777 Views)
Since I see a bit of interest in this, here is a cheap-n-dirty version of my guitar tuner.  It was written to work with frequencies as low as A0 (27.5Hz) and as high as G6# (1661.218Hz).  Please feel free to critique and/or comment on it.  I added the ability for the user to change the "tolerance" for a note to be consider "just right" (tuned properly).  By default, it is +/- 0.2% of the note's ideal frequency.  I also added the ability for the user to adjust the amplitude threshold for the mic input.  It was based off of the "continuous sound input" example VI.
One thing I plan on doing is adding an actual list of available sound input devices instead of a [seemingly] arbitrary 0, 1, 2... numeric control for the input device.
Message 13 of 13
(2,690 Views)
