HASP failure
I was using the Aladdin HASP with my LabView application. We discovered that with all NT versions, if the dongle is removed the application continues cheerfully. When I manually installed the new HASP driver, it operated normally.
I updated the AppBuilder with the new HASP driver, and now it does the same thing as the old one. It seems that HASP misbehaves according to the install method, not according to the HASP driver version.
Any ideas on this issue?
(2,918 Views)
Hello:
I have problems with my HASP. I would like to know how I have to generate an executable from LabVIEW 6.0.1 to protect it with the HASP. When I generate a exe file and I have protect it with the HASP, if i execute these protected file I have the next message: "This is the application template and cannot be run alone". What it means?.
(2,782 Views)
