the vi is not in a state compatible with this operation (subvi in a tab)
Should I move to another state?
I'm trying to run a vi (that works fine on it's own) in a subpanel control that's in a tab control.  This has got to be the most uninformative error message I've seen since I quit running fortran in dos.
One again I'm
Clueless1
LV 8.6 on Windoze XP
(5,160 Views)
Is the sub-vi already running somewhere else in your main vi?
(5,143 Views)
 I think a VI loaded into a subpanel (this is what you are doing right?) should already be running, so run the VI (by reference/dynamically) and load the reference into the sub-panel
(all examples with subpanels will show this)
Ton
My LabVIEW Ideas
(5,140 Views)
Clueless,
        A search for "the vi is not in a state compatible with this operation" on NI.com yielded:
KB 194A7UU0: What Is the Meaning of "Error 1000: The VI is not in a state compatible with this oper...
Cheers,
NathanT
(5,119 Views)
(5,113 Views)
