HELP -FPGA SPARTAN 3E-100 CP132 WORKS WITH LABVIEW FPGA ?
HI EVERYBODY, IM TRYING TO USE MY FPGA BOARD WITH LABVIEW, BUT I DONT KNOW THAT IF ITS COMPATIBLE, I INSTALLED DRIVERS, FPGA MODULE, AND LABVIEW 2012, IM USING WINDOWS 7 32 BITS, AND AFTER I COMPILE ITS SAID :
LabVIEW FPGA called another software component, and that component returned the following error:
Error Code: -310601
NI-COBS:  Unable to detect communication cable.
Please verify that the communication cable is plugged securely into your computer and target. Also verify that the appropriate drivers are installed.
THANK YOU .
(3,515 Views)
Accepted by topic author dvaldez2
Hi dvaldez2.
LabVIEW FPGA does not offer support for any third party hardware, other than the Spartan 3E XUP Starter Kit. Those are probably the drivers you downloaded.
http://digital.ni.com/express.nsf/bycode/spartan3e?opendocument&lang=en&node=seminar_US
However, this driver only supports the Starter Kit board itself (http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,400,790&Prod=S3EBOARD). You can't use the driver with any other FPGA from Xilinx.
Hope this helps.
Aldo H
Ingenieria de Aplicaciones
(3,475 Views)
thank you very much Aldo,
and for your time,  😃
regards
David Valdez 🙂
(3,463 Views)
