How do I read 2 CSV files of line by line match/compare and if no match flag and display error with location of error?
I’m new in LabVIEW and have searched for any examples of what I’m trying to accomplish with no luck and I seriously need some help!! How do I read 2 CSV files line by line match/compare and if no match flag and display error with location of the error? My files have over 1000 lines. I have attached a flow chart to reflect what I’m trying to achieve.
Message 1 of 20
(4,260 Views)
Read both files simultaneously in a loop a line at a time.  Compare the strings.  If they are not equal, stop the loop, display the strings.  By reading the i terminal of the loop, you'll know which line of the file it stopped at.
Message 2 of 20
(4,256 Views)
compare the 2 arrays in a for loop and build an array for the location...
Spoiler
Message 3 of 20
(4,248 Views)
Spoiler
You don't even need the FOR loop.  Do the comparison on the arrays of lines and perform a Search 1D Array on the boolean for a False (assuming using Equal).  It will return the index of the first line that was different and a -1 if they lines were the same.
GCentral
Message 4 of 20
(4,225 Views)
None of the above post works. Maybe misunderstood. The idea is to read each line from the file and compare to a corresponding line (known results) and if they match flag a pass/fail. Need to do this sequencially my files have strings stored in a 1D array as csv file. Any help is really appreciated and thank you.
Like
file1   file2   results
This is a stop sign This is a stop sign pass
Cross walk stop   Fail
Message 5 of 20
(4,201 Views)
Attach your VI and your example files.
I'm sure it will work.  It must be something in your implementation.
Message 6 of 20
(4,199 Views)
Accepted by topic author Maskan
Message 7 of 20
(4,194 Views)
That is a screenshot, not a VI.
So what is wrong with what is attached?
It looks like you have the array broken up into words rather than lines.  In which case the problem is where you read in the data file and created an array out of that.
Since you didn't attach a VI that shows that part of your operation, I can't comment on that.
Message 8 of 20
(4,190 Views)
Ravens: Different posters.
OP: APOK has the solution right there for you.
GCentral
Message 9 of 20
(4,180 Views)
crossrulz wrote:Ravens: Different posters.
You're right!  I must have merged a couple of posts together in my mind when I read them.
But the part about an array of words vs.an array of lines still applies.
Message 10 of 20
(4,174 Views)
