HELP PLEASE :compare timestamps with excel and take corresponding value in neighboring column
I have attached the program I have done so far and the txt file required by the program.
I want to compare the timestamp given by me at the begining of the program and when it is true, I want to take the corresponding neighbouring value and use it for calculation.
I am able to compare the time but i do not know how to take the corresponding '0' or '1' value from the file.
I am a beginer to labview. This may be basic but I couldnt figure it out yet,
Kindly help.
Thanks in advance
Arun
(3,286 Views)
atleast any comments please...
(3,253 Views)
Accepted by arun.vinayagam
This?  If you get a match, search the 1D array of booleans for a True and use that element's index to get the next column's data.
Jim
(3,144 Views)
thanks a lot... It works
(3,115 Views)
