HELP! with Tools pallete
Suddenly, I can't get the tools pallete to display. Under Windows,
Functions and Control palletes pop up ok, but Tools won't. I can't get
the wire spool or anything. Any help other than re-instal?
(3,159 Views)
Try to change your screen resolution to a higher one, once i had a similar problem, and the tool palette was outside the screen limits.
Hope this helps
(3,159 Views)
Oh, you might beright,I'll try it. Last time, I had to resolution up
hi. Thanks alot!
On Sat, 8 Dec 2001 16:48:44 -0800 (PST), Gorka Larrea
>Hope this helps
(3,159 Views)
You might also like to try looking in the LabVIEW.ini file there may be a line in there that looks similar to this : toolPaletteLoc=24,35,154,113. It determines the location of the tools pallete. Setting all the values to zero will ,make the pallete appear in the top left of the screen.
(3,159 Views)
Hope you got the Tools pallete from the previous answers. You can also use the Tab key in your keyboard to select the different tools (cursors), so you don't need the Tools pallete always open.
Enrique
www.vartortech.com
(3,159 Views)
Pressing over a LabVIEW window will display
a copy of the tools pallete just at the tip of your cursor (at least
under Win NT 4.0, SP6a, LV 6.02).
(3,159 Views)
