Selecting only one boolean inside cluster at a time
I have multiple check box inside cluster and I want to select only one check box at a time.
Any idea/suggestion would be highly appreciated.
(3,194 Views)
Hi Seree,
Attached is a LabView 6.0.2 VI showing a couple of ways.
Regards
Ray Farmer
Regards
Ray Farmer
(3,194 Views)
I have only Labview 5.1.
Could you please help to save as 5.1 format?
(3,194 Views)
attached lv5.1 example.
Regards
Ray Farmer
Regards
Ray Farmer
(3,194 Views)
If you want to create something like RadioGroup you can see the example attached.
Oleg Chutko
(3,194 Views)
