HOW TAKE ARNGE
Dear Sir / Madam,
Dear sir I want to take a range from 1-D data file. Like file having value 0-90, I want to take values which have 0-10, 11-20, 21-30, 31-40, 41-50, 51,60, 61-70,  71-80, and 81-90,  Here I have attached file  image file of results.
Message 1 of 13
(4,378 Views)
Ok, what have you tried?  Sounds to me that you will need a simple FOR loop with a shift register for each bucket.  Use a case structure to add to the proper array when in a certain range (the case structure does take numerics).
Message 2 of 13
(4,365 Views)
Or, a simply use the histogram.vi on the signal analisys palatte.  (Sorry no example I'm ugrading to dev suite 2012 this afternoon)  Crossrulz can you carry that one for me?
Message 3 of 13
(4,362 Views)
I don't see how a histogram is going to give him what he wants.  The histogram VIs only give the counts of each bin, not the values that went into a bin.  Or am I missing something?
Message 4 of 13
(4,354 Views)
Just thinking a step ahead.  Why else bin the values?
Message 5 of 13
(4,350 Views)
Here ,,
I have attached a program and file, is it correct?
Message 6 of 13
(4,345 Views)
That looks like it should work.
But to save you a little on the read side, you can right-click on the Read Text File and tell it to read lines.  Then wire -1 to the count in order to read all of the lines.  You can then use a Fractional String to Number converter on the read array to get your 1D array of numbers.
Message 7 of 13
(4,304 Views)
Dear Sir,
Thanks for positive response, please help me a little more,
This program is working fine fine for less range, but for larger ones, like 0-10, 10-20,20-30,,,,,,,,,,,. 350-360, this program makes lost in confusion please suggest me another way to take range form 1-d array file.
Thanks & Regards
Prince.
Message 8 of 13
(4,274 Views)
Sort array. threshold array in an autoindexed loop. mobile again so no example . anyone?
Message 9 of 13
(4,264 Views)
Accepted by Julian_prince
Hi Jeff,
here you go:
I create an array of cluster of array to store 1D arrays of different length in an (kind of root) array...
Message 10 of 13
(4,256 Views)
