HOW TO CONFIGURE SHIFT ?
hi,
i am making a report that should be automatically show the shift name.
from every daya morning
6:30AM to 11:30 AM = shift A
12:00PM to 3:30 PM= shift B
4:00PM to 9:00 PM= Shift C
10:00PM to 1:00AM = Shift D
2:00 AM to 5:00 AM = Shift C
how to configure like this, and how to change the shift name while this time changing?
Balaji DP
(3,078 Views)
Hi!
I would have used "Get Date/Time" function to see what time your computer's clock is. Then I would have checked if the time was within your limits. Based on that, a local Variable can easily be changed to contain your "Shift Name".
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,073 Views)
YES I DONE....
Balaji DP
(3,063 Views)
Well, your code works fine. The only problem I see, is when the time is between your shifts, the code should put something else. I.e "Lunchbreak" or something. Or you would have to remove these timespaces where your code cannot find anyting to put in your "Shiftname".
Example:
1200 - 1300 = Shift A
1301 - 1359 = Break After Shift A
1400 - 1500 = Shift B
1501 - 1529 = Break After Shift B
Or just include your breaks in shift A, like:
1200 - 1359 = Shift A
1400 - 1530 = shift B
Even
Topro AS
Norway
(3,054 Views)
