Open Tiff file error
Hi!
I've a very big tiff file, created by a scanner.
The scanner produces tiff files from my code, but the shipped SW can produce pdf.
My question is, how can I open this large tiff file in Labview (Vision)?
Using the Shipped SW I scanned a PDF and using Ghostscript I could convert the pdf to png and after the conversion I could open it!
Is there any way to convert this big tiff file to open in LV?
IMAGE:http://data.hu/get/3787417/Irbesartan_393356_2.tif
+++ In God we believe, in Trance we Trust +++
[Hungary]
(2,682 Views)
Hi Durnek,
My first idea is to convert it from tiff to some light-weight format (i.e. BMP or lossy JPG) - you may do it i.e. controlling MS Paint via ActiveX.
Also, I would like to ask you which function/SW are you using to open/read this file? Could you also prove the image in the other way? (I am redirected to Hungarian portal - I can't easily download it).
Thanks and BR,
Wojciech.
(2,665 Views)
