HOW TO DRAW THIS VI:NESTED WHILE LOOP
I've been doing C and javascript lately where curly braces for code blocks and semicolons for end of command rule the day.
Knowing how hard it is to get indentation right on code editors, I'd be scared that code will suddenly change.
But having an environment where appearance on screen and code structure are linked seems like a good idea.
Message 11 of 16
(988 Views)
    Wp = 0
    i = 0
    while i < 5:
        j = 0
        while j < 5:
            w = i * j
            Wp = Wp+w
            j += 1
        i += 1
i_f= 10 + Wp
I want to add and store values and use them outside the loop.
Message 12 of 16
(1,009 Views)
Seems like your garden variety nested For Loop problem. Where are you stuck?
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 13 of 16
(1,005 Views)
My main intention is this PYTHON CODE
Re: How to apply bilateral filter - NI Community
def apply_bilateral_filter(source, filtered_image, x, y, diameter, sigma_i, sigma_s):
    hl = diameter/2
    i_filtered = 0
    Wp = 0
    i = 0
    while i < diameter:
        j = 0
        while j < diameter:
            neighbour_x = x - (hl - i)
            neighbour_y = y - (hl - j)
            if neighbour_x >= 360:
                neighbour_x -= 360
            if neighbour_y >= 360:
                neighbour_y -= 360
            gi = gaussian(source[neighbour_x][neighbour_y] - source[x][y], sigma_i)
            gs = gaussian(distance(neighbour_x, neighbour_y, x, y), sigma_s)
            w = gi * gs
            i_filtered += source[neighbour_x][neighbour_y] * w
            Wp += w  // *************STUCK AT HERE**********///
            j += 1
        i += 1
    i_filtered = i_filtered / Wp
    filtered_image[x][y] = int(round(i_filtered))
Message 14 of 16
(999 Views)
Accepted by topic author gptshubham595
Well, that code is quite "spaghettified" but somewhere or another, you're going to need a shift register to keep track of i_filtered. You'll only need two loops also, not four. This is the solution to your original post, see if it gives you some ideas.
Spoiler
Redhawk
Message 15 of 16
(984 Views)
If you are not familiar with loops and shift registers, I would recommend you learn more about LabVIEW from here. How to Learn LV
Message 16 of 16
(975 Views)
