HOW TO FIX THIS CODE LABVIEW
how to fix this?
Message 1 of 21
(3,818 Views)
Use Merge errors from the Dialog & User Interface palette instead of Build Array.
Paolo
Message 2 of 21
(3,816 Views)
Message 3 of 21
(3,731 Views)
Well now please explain why you insist in building an array...
Paolo
Message 4 of 21
(3,726 Views)
Throw another Merge Errors after the Build Array.
(Just kidding- get rid of Build Array altogether)
Message 5 of 21
(3,715 Views)
Change the mechanical action of the control to a "switch" mode. By default it's "latch when released".
Boolean control on latch do not permit to use local variable for it.
Message 6 of 21
(3,692 Views)
This is bad advice.  First of all, it doesn't look like the OP is even using a second loop.  Secondly, a different way of passing the data should be used over local variables, a Notifier immediately comes to mind.
Message 7 of 21
(3,680 Views)
The broken wire has absolutely nothing to do with mechanical action or local variables. Your response is completely off-topic.
(And if somebody blindly changes to switch action in order to create swarms of local variables, something else is wrong 😄 )
Message 8 of 21
(3,674 Views)
True @crossrulz, thanks for correcting.
Message 9 of 21
(3,653 Views)
Use unbundle by name and use error status of each error and do logical OR of each error status then stop if true condition works ok and broken error will be removed
Message 10 of 21
(3,528 Views)
