HOW TO GET REFFERENCE OF INDICATOR OF TYPE DEF CLUSTRE
Have 2 quastions:
1. Have a type def culster of boolian indicators.
    how to extract individual references so I can pass them to sub vi.
2. Since bollian indicators dont latch its value.
    Can I make an array of boolian indicators that will keep its value hen passes to sub vi.
Thanks.
Message 1 of 12
(4,551 Views)
Accepted by Metachnet
why do you want to pass individual reference to a subvi ? pass cluster reference.
Indicators keep the value what has been assigned to them. what do you mean by indicators do not latch its value.
Message 2 of 12
(4,544 Views)
Have a state machine.
I write TRUE to Boolian Indicator, and then go next to next state.
When I return to the Begining State Machine state again it looks that the boolian lost its previos TRUE value.
Message 3 of 12
(4,535 Views)
Have tried your concept and it provides me with actual value, but I need the individual reference of each element. thanks.
Message 4 of 12
(4,505 Views)
What do you think those skinny little lines connecting the array index and the value property nodes are?
Bill
CLD
(Mid-Level minion.)
Message 5 of 12
(4,494 Views)
Thanks Billko
Message 6 of 12
(4,467 Views)
@Neos wrote:
Thanks Billko
Hey, I re-read my comment and it sounded kinda snarky.  Sorry about that, it was supposed to be silly, not sarcastic.
The example might have been clearer had it included reference indicators instead of ending in property nodes.  That kind of threw you off the track.
Bill
CLD
(Mid-Level minion.)
Message 7 of 12
(4,461 Views)
Actually the example was to just show how to get reference of individual controls of cluster.
whatever the OP wants to do with refrences its his choice.
Message 8 of 12
(4,458 Views)
Firstly, I got a little confused because you had thanked me and so I thought you were the OP for a moment.
Secondly, though - your example added just enough obfuscation that the OP did not understand that this was actually an exercise to get references from a cluster.
I know you used the property nodes to bring out the reference wires.  If the wires were connected to indicators that said "control reference" it would probably have been clearer.
One thing you should note is that if a pupil does not get the concept you are trying to teach, 99% of the time it is the teacher's fault.
Bill
CLD
(Mid-Level minion.)
Message 9 of 12
(4,452 Views)
I agree.
But sometimes it is okay to give just an idea or clue of what to do and let OP learn that.
Still i take this as my fault.
Message 10 of 12
(4,443 Views)
