Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
HOW TO WRITE A COMMAND NOT AVAILABLE ON AN IVI DRIVER
NancyLynn
Member
11-17-2004
11:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to write a command to my DMM and it is not available on the IVI DMM driver vis. How do I do this?
Labview 7.1, Windows 2000.
0
Kudos
Message
1
of 3
(2,575 Views)
Reply
Re: HOW TO WRITE A COMMAND NOT AVAILABLE ON AN IVI DRIVER
Dennis_Knutson
Knight of NI
11-17-2004
12:00 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Should be able to just use a VISA Write with the correct VISA Resource Name.
0
Kudos
Message
2
of 3
(2,575 Views)
Reply
gagi1
Active Participant
11-18-2004
08:58 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Nancy,
If you are using an IVI driver developed by NI, you should use two specific driver VIs provided with the driver:
Write Instrument Data.vi
Read Instrument Data.vi
These VIs can be found under the Utility>Instrument I/O palette.
I hope this helps.
Vesna
1
Kudo
Message
3
of 3
(2,575 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
