HP latop hangs on second CD for LabVIEW device driver install
I just received  a new HP laptop. On both LabVIEW 7.1 and 8.2.1 so far I installed LabVIEW OK. The install  then asks for the Device drivers CD and it installes OK. The install calls for the second CD, I remove the first one, put the second one in the drive and wait for hours for it to be recognized. It never gets recognized. I hit the "Rescan" button. An hour glass cursor comes up and stays there for hours. When I try to cancel, close the window, whatever, nothing happens. The task manager will not end the task. I have to used the task manager to shut down the computer. Does anyone have any ideas how to fis this?
Thank you,
Chuck Lippmeier
(4,502 Views)
hai
 go for the other new set of device drivers. this happens many times during my early days....nothing to do with anything
(4,495 Views)
I use to do that until I started to do installation builds. I now copy each of the CDs into an installation area on the comuter. When it prompts for the disk, i just point to this location. When it needs the second disk, I point to the next location and so forth.
(4,490 Views)
does it works
(4,485 Views)
I have been doing this since 8.0 on the development station.
(4,476 Views)
Ya, I copied the 3 cd set to a directory on the hard drive. CD 2 and 3 have all the relavent stuff in a dir named "Products" CD 1 has a "Products" dir too. I copied everything from all "Products" directories to the one on the hard drive. Then I edited the setup.ini file. I found all Volume=2 and Volume=3 entries and replaced them with Volume=1. Then, to install I just double-clicked autorun. This seems to work. However, I shouldn't have to do this. What I really what is a way to fix the CD problem so I can intall everything the right way from the CD.
Chuck Lippmeier
(4,472 Views)
That would be nice.
Have you tried that with  your laptop? I find that the disk drive installation to be more reliable than CD.
(4,467 Views)
