HP3661A drivers not online!!!
I could not find LabVIEW drivers for the HP3561A dynamic signal analyzer online.  I've got access to LabVIEW 6 and 7.  Can someone please send them to me?  Thanks in advance!!
(2,747 Views)
The HP3561A drivers are right here. What did you search for? The topic of your message says 3661 but in the body, you have 3561.
(2,744 Views)
Thanks!!  I see what you did.  You used the "Search Drivers" option under "NI Developer Zone".   I starting from the NI home page, I clicked on "support".  When that page loaded, I selected "Divers and Updates" and typed in "HP3561A" in the keyword field.  That query returned no results!!
(2,735 Views)
Very much the wrong the wrong set of drivers.Smiley Wink I never noticed how that could be confusing. On the main page, the very last item under the Get Support column is the link to the Instrument Driver Network.
Also, with LabVIEW 8.x, you can go to Tools>Instrumentation and either start the search from there or connect to the instrument driver network.
(2,732 Views)
