HP4276A
I downloaded HP4267A from NI.
I use a GPIB-USB cable to connect HP4276A and the GPIB address is 17.
I tried "HP4276A Example.vi" and a window poped up, "Error 0 occured at HP4276A Config Measurement;HP4276 Send" Message".
Please give me some suggestions.
(3,693 Views)
Accepted by topic author lfzhang
Did you read the explanation of the error? Are you actually using an NI GPIB-USB device? If so, did you perform the basic tests of it and does it appear in MAX?
(3,680 Views)
Hi
You can have to check the your GPIB address again. Afterthat, make a small vi which is just communicating with your Instrument or open MAX and try to send the such as "IDN?" command.
Also, I'm not sure that remote / local switch available on the front panel of instrument. if yes then press remote switch which give the connection with GPIB.
(3,677 Views)
After the intallation of the driver for GPIB-USB-HS cable, everything works well.
Thanks a lot!
(3,665 Views)
