HPF file opener
I'm trying to open HPF file.
I attached the .VI and the file.
I would also like to know how to read hpf. files faster. It takes almost 5 - 10 minutes to open a file. The file size is usually around 300Mb.
Thank you in advance,
Evyatar
(1,443 Views)
Hi Evya,
You forgot the most important parts of the message…
(1,429 Views)
I'm sorry, I was sure I did.
Let's try again.
I attached a file that works and one that doesn't work.
My concern is with the amount of channels, is it possible that there are too many?
*The file that doesn't work is not empty for sure or corrupted. I manage to open it with EMGworks and to export to csv.
(1,358 Views)
Hi Evya,
unfortunately I don't have that dataplugin installed, so I cannot run your VI…
General suggestion: when attaching files you should use ZIP to compress archives. Using proprietary paid software (aka RAR) instead makes it unusabvle to many people…
(1,340 Views)
