hallo anggota labview ,disini saya memiliki masalah dalam melakukan comunikasi serial sensor Arus PZEM-004T melalui arduino ke labview, mohon solusiny
Bagi anggota yang mengerti atau pernah mengerjakan projetc menggunakan sensor PZEM ,saya meminta tolong sudi kiranya untuk berbagi solusinya, terimakasih.
(928 Views)
Hi alfi,
it really would help to write in English in this worldwide forum!
@Alfi29 wrote:
hello labview members, here I have a problem communicating the PZEM-004T Current sensor serial via Arduino to labview, please provide a solution
For members who understand or have worked on a project using the PZEM sensor, I ask you to share the solution, thank you.
So what exactly is your problem?
Does your Arduino correctly work with this current sensor?
Is your problem only the serial communication between Arduino and LabVIEW/host computer?
What have you tried and where are you stuck?
(892 Views)
