HTML Help Workshop; creating the *.chm file
I'm about to create the documentation for a large LabVIEW
automation project. I would also like to use this
documentation as the content for my help-file used by the
LabVIEW program (a *.chm or a *.hlp-file) via the
Control Online Help.VI.
The question is, what is the most optimal way to create this document,
without having to do the job almost twice ?
Normally I would create the documentation as a Word-document.
But as far as I see, the help-file system has to be created by the
MS HTML Help Workshop program, and that uses a large collection
of html-files to compile into the CHM file. And the html-files that
can be exported from Word aren't optimal, are they, with
a lot of extra code etc...
Somebody have obvious
ly looked at this problem before me.
What are the tips, tricks and suggestions around ?
Martin
(6,013 Views)
Martin,
On the last point, you can strip
out most of the extraneous code by
running the HTML files through the Microsoft Office HTML Filter,
available from:
http://office.microsoft.com/Downloads/2000/Msohtmf2.aspx
And see the following for additional information on using
Word-generated HTML files in HTML Help:
http://helpware.net/FAR/far_faq.htm#wordhtml
If you do want to use Word as your main authoring tool, you could use
it in combination with one of the following to single-source print and
online documentation:
WebWorks Publisher WordHelp (http://www.webworks.com)
AVHelp (http://www.avsoft.it)
Doc-To-Help (http://www.componentone.com)
RoboHelp (http://www.ehelp.com)
The following resources may help you to choose a help tool that best
meets your needs:
Tools Comparison Matrix:
http://www.helpstuff.com/downloads/toolsv5.pdf (Acrobat 5 format)
http://www.helpstuff.com/downloads/toolsv4.pdf (Acrobat 4 format)
Which Help Authoring Tool(s) Do You Choose?
http://www.helpstuff.com/downloads/HATcomparison.ppt
Review of Ro
boHelp Office 2002:
http://www.winwriters.com/robohelp02_pt1.htm
Review of Doc-To-Help 6.0:
http://www.winwriters.com/dth6.htm
Pete
(6,013 Views)
For everbody else in the audience, check out
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/htmlhelp/ht
ml/vsconHH1Start.asp to download the free HTML help workshop. It is a
package which takes a set of HTML files and generates a standard win2k/XP
helpfile.
However, your point is completely true: it just a major pain to make a
"pretty" version of both offline and online help. Both documents can have
the same content: a section explaining each menu item, several sections to
explain common tasks, a section explaining terms, etc. I dont see a huge
difference in usability as long as you create a union of material.
As for exporting I haven't found a good solution. As you've seen, you must
have the seperate HTML files for the help compiler. That's how the table of
contents, etc is generated. For my current project, I maintain that as a
frontpage web and apply a cascading style sheet. I didn't find a good way to
(automatically) split the word document into several HTML files or join the
frontpage web into a single organized word file. It wasn't a huge issue,
because I ended up using printed material as an installation guide and
online help as program documentation.
The one particularily useful thing was programming a custom "document my
progam" VI which exports using my special documentation format. Of course
that is really only suitable for the programmer's reference section. However
I really, really, really hated using Print -> VI documentation and
reformatting every time. I'm sure you'll soon notice that it gets tiring.
-joey
"CatLabMan" wrote in message
news:1042528495.741807@halvan.trd.sintef.no...
> Somebody have obviously looked at this problem before me.
> Martin
(6,013 Views)
hi,
I also designed a software in labwindows and I want to make "help" for this software as every software have a help option and most of the documentation resides under this,
I have no idea how can I make a .chm or html file for the "help" documentation of my software,any body please?
(5,121 Views)
